TPS question
Firebladez
TPS question
Post by Firebladez »
I have k-pro, k20A3 engine, RBC intake manifold, i changed over to a type-s T/B, along with all the base T/B sensors. Only one problem i'm haven tho. The TPS is telling me it's 40% open @ idle, yet i see it's closed. When i open the throttle 100% the kManager is telling me it's 0% open, Then my engine almost dies.
Any suggestions on my problem?
Thx's for your time.
I do not believe you can use the Base TPS sensor on a Type S TB as they rotate in opposite directions.
Firebladez
K just came back from taken off the TPS agian and now i see what u mean, didn't really look at it when i took it off the base type. Ty for the help, Next tast is to find a type-S TPS now. do u know any companies that make an aftermarket TPS?
You can buy one through any Hondata dealer.
6spd_ek
Post by 6spd_ek »
what about an older k24a4 or a1 (accord/element/crv)? could one of those TPS be interchangeable?
If they rotate the same direction as the throttle body you have then they will work, if not they will not work.
6spd_ek
Post by 6spd_ek »
cool the k24a4 accords (early models pre '05 i believe) open the same direction
jdmspecdc5
Post by jdmspecdc5 »
did you switch the wires on the tps plug? the wiring for a base tps and type-s tps are opposite of each other.
talonxracer
Post by talonxracer »
Omni-Power carries new TPS sensors for the typeS TB.
