Romeditor4 V1.1.0
ROM Editor 4 tuning software questions and answers.
Romeditor4 V1.1.0
Changes:
- Fixed service connector switch not flashing check engine light.
- Fixed MAP sensor parameters not reloading.
- Added autotune to Settings.
- Added WinQual certified USB drivers.
Download here
V-Spec race development
Post by V-Spec race development »
Thank you. I have a question, when I'm datalogging and I click on display, I'm having a hardtime reading some of the numbers on the display, either the window is to small or the number in it is way to big and I can't see the whole numbers. For example, I want to see my ECT temp. and lets say it's 208*f, the number 2 is hardly showing on the display and so other windows/displays. How can I make the number smaller or make the display window bigger so all the numbers would show up and not half only. thanks a lot.
Click on the gauge, drag to make it wider or taller. If nothing happens when you click on a gauge, right click on the window and de-select 'lock controls'.
OK thanks, I will try that and I'll let you know.
The display is not user customizeable in Romeditor4 like it is in Kmanager and Smanager. The display size has never changed in this software. More than likely you have just changed the resolution of the screen settings on your laptop.
Is there any way you guys can add this feature? that would be great and much appreciated.
Sorry, there are no plans to add this feature.
