Reflash required - CEL P0113
s2kcrick
Post by s2kcrick »
Im having an issue with my 08 S2k CR, i have the Vortech SC kit that required the Hondata reflash.
The issue is that the CEL throwing code P0113. I had my tech check it out and the IAT sensor is still good. He stating that Honda has a bulletin out for this issue, that if the IAT sensor is good, then the ECU will need to be reflashed.
I dont think that I should take the car to the dealer and have them reflash the ECU since that will put it back to stock form, which will not work with the supercharger.
How do I go about getting the ECU reflashed again?
Thanks.
I believe you have been in contact with Doug, so please follow his instructions.
