Hytech Stage 1 Kit
silverspoon1996
Hytech Stage 1 Kit
Post by silverspoon1996 »
I currently have a reflash for it, Is it possible to get the map?
There never was a Hytech reflash. You have the normal Hondata reflash, so you cna just use one of the built in reflashes in the software.
silverspoon1996
Are you sure you guys never did a custom reflash for John?? I paid for 2 reflashes. Once from a shop in Illinois and one from Hytech. It was the same ecu, John called me up and asked me if I wanted to reflash My ecu again because it was already flashed, and I couldnt go back once it was reflashed.
If there was never a reflash for these cams and header, I paid an extra 600 dollars that was completely unnessesary.
Send us your ECU part number and serial number (the part number starts with 37820, the serial number is underneath that), and we'll look up the history of the ECU and see if we reflashed it, and what reflash was put in it.
silverspoon1996
4744-133553
John told me today, that I need to get the Calibration through him, and he would talk to you, Doug.
This ECU was reflashed one time on 1/15/08 by APG Performance with a standard Hondata reflash.
silverspoon1996
Well then I guess I have a problem with Hytech, I did pay them for a second reflash supposibly specific to parts I bought from him. I believe it was August of this past year.
silverspoon1996
How do I go about getting a refund for a reflash never done??
If you paid for this through Hytech, you will need to contact them for a refund as we have no record of ever charging Hytech for a reflash.
silverspoon1996
ok thank you
