Help with map
teflonbless
Help with map
Post by teflonbless »
I have a aem sri/rh/catback
i was using the aem sri/rh/catback MAF/AFM it runs beautifully
i tried the MAP aem sri/rh/ctaback and when it idled it was about to shut off
then my Oil life was -2
soembody from hondata told me how to reset it i did..
but they said it will happen when i go from MAP to MAF
i have the MAF base now i want to change it to MAP
is this possible for n/a guys they have a basemap for it
- Oil life - this will need to be reset when switching from the MAP to AFM calibration. I've added the procedure to the help file.
- MAP calibration.
You'll need to describe the exact problem in a little more detail - does the car run ok except for the idle, or is it running so lean/rich that it will not idle?
Check the injector size is set correctly - it should be 310cc. Do a brief datalog and post it here, or look at the fuel trims when the car is idling. You'll need to find the AF, S.TRIM and L.TRIM sensors when the car is idling and you're datalogging.
teflonbless
ok thanks i will do that
before it was just idling and sounded like the car was about to shut off then it would catch itself but other to that it ran great
