Couple of questions
Quade
Couple of questions
Post by Quade »
Is there a maximum value for the fuel map table that represents maximum flow of the injectors?
My IAT and ECT readings in the display bar are way off when datalogging...........what's wrong. The readings are 67F and 94F respectively when fully warm. Using a PO6 S300 on an H22.
There is no maximum nuberic value as the numbers in the fuel tables have not direct meaning. They are a number that is used and modified by the fuel trim and other parameters you have set.
You have not provided enough information to understand the issue you are reporting. http://www.hondata.com/forum/viewtopic.php?t=3772
Quade
Post by Quade »
I think found the reason why. The sensor setup under "Options, Sensors" were set to degrees celcius and the display bar shows degrees fahrenheit as the units. This is how the prelude.skl comes by default so it would throw a newbie off like myself. Am I correct?
These settings are not dependant on the calibration. These are global settings set by the user.
