Fn2 type R problems
nunoctr
Fn2 type R problems
Post by nunoctr »
Hi hondata,
I think there is a bug/problem with the group N calibration.
installed the OEM ECU and flash it with the hondata reflash group N calibration.
soon after a error code:“P0141 O2 sensor heater circuit malfunction Bank 1 Sensor 2". Engine light on.
After some km the engine oil light was on also.
With the hondata reflash group N ECU there were any of this problems
After I flashed to the ECU a MAP calibration.
There were problems with all the fuel guages in car computer: The instant fuel consumption was 30 liters, there were 0 km to empty fuel tank and average fuel consuption was not working.
put back my hondata reflash ECU and everything is fine again.
I have a race header and exhaust only.
I need your help hondata.
Ok, we're looking at it.
mw1978
Post by mw1978 »
HONDATA i have the same problem as above. GroupN calibration on FLASHPRO desn't have possibility ON/OFF secondary oxygen sensor!!!
With MAP calibration I have the same problem on my dash as above :(
I have intake header and exhaust
guwester
Post by guwester »
I have the same problem with the MAP calibration for my FN2
mw1978
Post by mw1978 »
HONDATA after i installed new flashpro soft 1.3 problem with secendary sensor is gone Now i can turn ON/OFF.
Later today i will check what will happend with MAP race calibration
we move forward!!! :D
The fuel / trip meter is not going to work with the MAP calibration, neither is the oil level meter.
guwester
Post by guwester »
Hi Hondata
Does this mean that this problem with dash computer not working under MAP calibration cannot be fixed by you? or will you be working on a solution to solve this problem?
