ep3 gear ratio table
rocketep3
Post by rocketep3 »
I found this:
http://corporate.honda.com/press/articl ... 0070606581
it says the 2nd gear in the USDM 02 si has a ratio of 1.769. K-pro has it's ratio as 1.88.
What's the truth?
I do not know which information is accurate. There is always a possibility that at the time the software was created we had incorrect information. You can always go in and edit the calibration to suit your needs.
The base RSX & TSX have a 1.880 2nd gear, the EP3 has 1.769. I've corrected the ratios in KManager.
rocketep3
Post by rocketep3 »
ok, thank you
