RDX Injectors
silverspoon1996
RDX Injectors
Post by silverspoon1996 »
I just Bought RDX injectors and plan on installing them at my house before I get tuned.. How safe is the base map for driving 3 hours to a tuner??
I am running 12:1+ Compression pistons and Hytech Stage 1 cams.
You will have to change the settings and upload the changes to your ecu in order to use them. If you do not feel comfortable doing this I would suggest waiting to install the injectors until you get to the dyno.
silverspoon1996
ok thank you.
