FlashPro on FN2 Cruise Control problem
walter
Post by walter »
I have a problem with cruise control on 6th gear, it doesn't work. I tried Group N reflash and "MAP based, race header, highflow cat, stock catback." for FN2 calibrations. It works on 5th gear fine, but on 6th it works only when rpm's are at 2k-3k.
We are looking into this. Can you please provide a datalog showing the problem?
walter
Post by walter »
Spunkster wrote:We are looking into this. Can you please provide a datalog showing the problem?
Cruise control only works on MAP calibrations but not on 6th gear, on MAF (Groupe N reflash) I can't even switch it on. I'll make datalog tomorow.
Do you have a Type R GT? What is the ECU code number?
walter
Post by walter »
Spunkster wrote:Do you have a Type R GT? What is the ECU code number?
Yes, Type-R GT. ECU code number: RSP-E03.
With MAF Groupe N reflash cruise control doesn't work at all.
With MAP raceheader tuned, when I mark "Cruise control enabled" in "Misc" it works, but not on 6th gear.
On which calibration I should datalog?
walter
Post by walter »
I've made two datalogs with "Group N Reflash" and "MAP based, race header, highflow cat, stock catback" calibrations.
Could you advice which calibration is better to use with bolts on like header, catback, hondata heat gasket? It seems that MAP based runs better...
nunoctr
Post by nunoctr »
same problem. :(
chris87
Post by chris87 »
I have the same problem, the automotive cruise control don't work at any gear..
i only reflash the ECU with Hondata Group N Calibration
can you help ?
We are still looking into this. It appears to only be an issue with the Type R GT since it uses a different ECU than the Base Type R. This was not something we were made aware of until now.
nunoctr
Post by nunoctr »
hondata please note that I have a FN2 GT (the only that have cruise control) and with my reflash ECU hondata group N the cruise control works fine. I have this ECU for almost a year
now with the OEM ECU with the flashpro the cruise control dosen't work.
chris87
Post by chris87 »
thats right, with the Hondata Reflash ECU the Cruisecontrol works fine but with the OEM ECU and the Hondata Group N Calibration it doesnt work.
Please Hondata fix it soon !
dinoc
Post by dinoc »
I'm looking forward for this fix, too.
Euro Honda Accord CL9
Andreyka123
Post by Andreyka123 »
I'm waiting this fix too...
FN2 '07
walter
Post by walter »
I think, everybody is waiting for this fix :D... Because you can't rest when driving on motorways :)
FN2 R-04455
Are you using the stock ECU or the Group-N ECU with the FlashPro?
