AF correction and lambda adjustment?
soxfan143
Post by soxfan143 »
Hello Hondata. I have a question about the AF correction value. Does it apply to the lambda adjustment values in the data logs or is it still the actual AF reading that is applied. And does the AF correction take the EGTs into effect with a boosted car or is this just for NA setups? Thanks.
Never mind. I can see the same values in the lambda tables as in the sensor. But does it adjust for the higher EGTs from boost?
No, our testing showed that the EGT did not affect the o2 reading.
soxfan143
Post by soxfan143 »
Hondata wrote:No, our testing showed that the EGT did not affect the o2 reading.
Awesome. So I can actually adjust fuel now without worrying about going too lean?
