VTC not Engaging
Jordo
VTC not Engaging
Post by Jordo »
When I data log my car for some reason its not switching cam angles at all. Its only staying at 0 degrees.
k20z1
gt35r turbo kit
kpro
any ideas fellas?
When I data log WOT, they are all at 0 degrees.
s300
What is the serial number of the K-Pro board inside the ECU?
Jordo
Post by Jordo »
hardware version 2.16
Serial Number 04997
s300
What vehicle is this in, and what wiring harness was used?
Jordo
Post by Jordo »
dc2 car, and hybrid racing harness.
s300
Jordo
Post by Jordo »
When I look at my calbration and my cam angles they range from 0-30 depending on load.
Now when I datalog it only datalogs 0 degrees.
I do have my "vtec oil pressure sensor disabled". im going to try to enable it and see if that allows it to work.
s300
What engine harness was used?
Jordo
Post by Jordo »
K20a2 engine harness
s300
Try your ECU in another known good vehicle such as an 02-05 RSX or Civic SI.
