version 1.1.0.5 questions
all-black
Post by all-black »
i was reading the new update
V1.1.0.5 (8 July 2009)
· Added Reflash Rebate information.
· Changed race calibrations to prevent long term fuel trim changing.
· Fixed cruise control for Euro CTR AFM calibrations.
· Added VTEC crossover tuning
but when i looked at the maps under race calibrations and try and see if there is a revision to the maps they still say version 1.00
so what changed and how will we know
nothign will change in the calibration list, but there are things which are changed in the calibration itself. You just need to either upload the saved calibration you have using the new version of software to apply the updates or use one of the base calibrations.
all-black
Post by all-black »
thats what i was asking, was that the calibrations would have changes in them but under there titles when you load them up to modify or load onto the fp the version says the same as before so thats why im asking. so how would you know which map is the old one verse the new one? are the changes in the software or in the calibration? you said, "You just need to either upload the saved claibration you have using the new version of software to apply the updates or use one of the base calibrations" im just trying to get some clarification thank you guys.
Simply by using the new software to upload the calibration, it has all updates applied to it.
ImAuthenticFTW
Post by ImAuthenticFTW »
All my calibrations have verson 1.01 listed in them.....
That will not be updated
ImAuthenticFTW
Just curious, but i use the MSD DashHawk which reads my AFR off the factory wideband (i know its not 100% accurate) ever since ive loaded another map with the update for the AFR correction i seem to be showing leaner (yet still safe ~13.3-13.9:1) did that update effect the way a scanner will read or should it still read the off numbers?
Use your laptop to datalog.
