KNOCK SENSOR
Govroom
KNOCK SENSOR
Post by Govroom »
How important is the knock sensor? Have people been able to retain it with the S300?
As long as you use a ECU that has knock control, then it will work, and it works quite well as long as you don't have forged pistons.
boosted crx-r
Post by boosted crx-r »
why is there a difference if you have forged pistons???
shut up and boost it!
forged pistons will have more slap in the bore and make noise like knock and be falsely detected as knock which will reduce the timing.
