Boost control components
teinxxx
Post by teinxxx »
How can I found out if my S300 has already installed the Boost control components...
So much with a little D
Compare the inside of your ecu to the one found at http://www.hondata.com/help/smanager/bo ... st+control
If you do not have the components it has not been prepared for bosot control.
teinxxx
Post by teinxxx »
Thanks A Lot this Help A Lot!!!!
teinxxx
Post by teinxxx »
My don't have the Boost control components so I gues i will sent ecu to yu guys... Again thanks a Lot!!
teinxxx
Post by teinxxx »
sine you are going to received my ecu to get the boost comp. could you download a basic map for me?
We do not provide custom base maps. There are base maps built in to the software you can use, or you can contact your tuner for a base map to help get you to the dyno for tuning.
