Urg.. Flashpro goes crazy..
skyliner
Post by skyliner »
Just tried flashpro,
register and lock the flashpro to the ecu
flash a base map..
after flashing..... damn... my car can't start, flash manager show ecu with a cross...
tried to upload again... still won't work..
tried to unlock, flashpro say vin not recognised...!!!!!
Arghhhh..
HONDATA... Help!!!!
For a start you will need to tell us:
- what vehicle you have
- what ECU you are using
- what calibration you have loaded
- if the ECU has been reflashed before
Unplug the FlashPro from the vehicle, switch the ignition off for at least 1 minute, plug the FlashPro back into the vehicle, connect to the laptop, switch on the ignition, then tell us what the icons are at the bottom left of the screen.
skyliner
Post by skyliner »
ok, will try the option out as advise first.
the car is FD2R 2008
Err..
the car is not flash before
First time flash status show ok.. but once flash, can't start car. icon show ecu x... bye bye.. can't unlock, can't do anything
ecu is RRC
I load the base stock map for testing.
Can you give the exact sequence of registration, locking, and uploading on your vehicle?
Had the ECU been reflashed before? Was the ECU 100% stock?
What is the part number and serial number on the ECU? The part number is 37820-xxxx followed by the serial number underneath.
skyliner
Post by skyliner »
register user details
register flash pro with hondata
open new calibration stock fd2r map
upload new calibration.. so far so good
upload stage 1 done, stage 2 done.... car can't start...
flashpro manager show ecu with a cross..
can't unlock, can't unregister.. but can flash... software only show stage 1
37820-RRC-.. need to check the last number.
just check my ecu.. the memory is wiped clean... no program at all...jeez..
august77
Post by august77 »
skyliner wrote:register user details
Hmmm... I did mine with FlashPro.. and it works fine.
Car can start and also run perfectly without a glitch.
try unlocking the FlashPro by reverting to stock map... then start the car. If car can start then u must have made a mistake while uploading the map to ECU.
Note: you must make sure ur ignition is at ON during the process.
skyliner
Post by skyliner »
i can't even revert now...
the ignition is on during the full process..
u don't mean the engine running right?
just on until there is power.? correct?
wildboar
Post by wildboar »
yeah. just turn ur key all the way. dun press the start button.
besides ecu showing a cross, what wat about ur odb2?
just wondering, did u do any reflash on ur stock ecu before?
august77
Post by august77 »
hi Skyliner..
Where are you located? Also, from who did you ordered your FlashPro from.?
Did you ordered the right FlashPro for your car? i.e FP-SI-INT which is meant only for CTR outside America.
skyliner
Post by skyliner »
no, the ecu is stock.
i use the int version flashpro for fd2r
i just got back my ecu from factory diagnostic.
they confirm that the ecu data have been wiped clean. no data in the ecu
they have just reload for me.
now, i can't even unlock the flashpro.... jeez
Update the software to V1.1.0.6, and then use the 'Send information to Hondata support' function (from the help menu).
Can you confirm that you are the same customer who I spoke to your dealer about today? You have a vehicle with the RRH ECU and have swapped in the RRC ECU.
hapv
Post by hapv »
Hello hondata,
I think I have this same problem today.
I install the new version 1.1.4.4; reflash my car to stock and drove for 20 minutes, then I want to upload a new calibration, during the process I receive a warning, since then my ECU is blocked.
I cant upload any calibration and the car doesnt start.
I attach the screen information, and send the information to hondata support.
My car is a 2008 Latinoamerican SI, K01, and the ECU has been reflashed before.
Please help
CLose the program, turn off the key and uplug the OBD2 port. Reconnect everythign and open the software and go laod a New calibration adn upload it to the ECU using the laptop. See if this resolves the problem.
hapv
Post by hapv »
I have made everything and there is not answer from the ECU.
If I upload a calibration with the laptop it only upload in the flashpro.
We use a scaner and have not answer from the ECU.
