newbie s300 questions (99 civic si/ex)
drummerdude
Post by drummerdude »
Hey guys, I'm a bit of a newbie when it comes to engine management and hondata, I have a couple questions I hope someone can answer for me.
Q#1) what, if any, functions will I lose going from obd2b ecu to an obd1 s300?
Q#2) in the display of the Smanager, do I need to buy an aftermarket a/f / lamba contoller/gauge to see the a/f in the display?
Q#3) is there a way to see oil pressure and oil temp in the display? if so what do I need to do to hook it up?
thanks for the help.
Re: newbie s300 questions (99 civic si/ex)
drummerdude wrote:Hey guys, I'm a bit of a newbie when it comes to engine management and hondata, I have a couple questions I hope someone can answer for me.
Q#1 - You won't loose anything but the OBD2 scan tool compatibility.
Q#2 - Yes you need an aftermarket wideband and controller to be able to datalog proper AF ratios.
Q#3 - http://plxdevices.com/sensormodules.html You can use the analog inputs in the smanager software.
drummerdude
THANKS
you are my hero. thanks for the quick replies, this forum is already made me feel more at home by leaps and bounds in my first day here, than I have at h-t in over a year. thanks again.
drummerdude
Spunkster wrote: Q#1 - You won't loose anything but the OBD2 scan tool compatibility.
one more question:
is it possible to see, and datalog egt and a/f while using the analog inputs for oil pressure and oil temp?
basically is it possible to hook up oil temp, oil pressure, egt, and a/f using plx modules into the s300 without losing any other functions?
drummerdude
so is it possible to have egt oil press, oil temp, and a/f all going into the s300 without losing any other functions?
drummerdude
is there enough inputs for egt, a/f, oil pressure, and oil temp??
You can to the Af and 2 of the others through the Analog Inputs.
drummerdude
ok, so I'll have to give up one of my oil gauges then.
