first motor swap
redline8000
first motor swap
Post by redline8000 »
hi guys, im stuck! im running a 1999 civic hatch dx with a b18a1 block and head and a b20 intake and ecu, im not sure if this swap is done right, i bought the car this way and im ready to make this b18 scream, what ecu and obd do i need to be running to get the acceleration that these b series has
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
