FJO Wideband installation question
se93
Post by se93 »
I have a doubt regarding the installation of the FJO unit. I got a hold of a dead O2 sensor plug, installed the resistor across both black wire, extended the white/green wires and connected it to the stock wiring harness. I took the gray wire of the FJO and connected that to the white wire coming from the dead O2 sensor plug. I installed the FJO ground wire together with the green wire (installed the diode as well) coming from the dead O2 sensor plug and the white wire from the FJO to a 12 volt source.
Is this correct?
Thanks,
Mark
DevineCRX
Post by DevineCRX »
ive never done it, but here is a article i found on interfacing the FJO and hondata.
http://www.boosted-hybrid.com/tech_articles/tech1.html
You can also find some helpful info at http://www.hondata.com/techwidebandtuning.html
