FJO Wideband installation question
Posted: Sun Oct 12, 2003 9:44 pm
I have a doubt regarding the installation of the FJO unit. I got a hold of a dead O2 sensor plug, installed the resistor across both black wire, extended the white/green wires and connected it to the stock wiring harness. I took the gray wire of the FJO and connected that to the white wire coming from the dead O2 sensor plug. I installed the FJO ground wire together with the green wire (installed the diode as well) coming from the dead O2 sensor plug and the white wire from the FJO to a 12 volt source.
Is this correct?
Thanks,
Mark
Is this correct?
Thanks,
Mark
