04-05 honda civic D17 turbo non-vtec basemap needed please
JoSoTurbo
Post by JoSoTurbo »
Hello, I have a dezod turbo kit using 310cc injectors with the non vtec D17. Hondata has a supplied vtec map for this app. Is it safe for me to use this as a starting point. I have to use this for a while because my tuner is booked up until Sept. Please help!
You can use it to start, but you will need to disable VTEC. I cannot tell you if it will be safe or not. YOu will need to monitor your AF and make sure it is not getting detonation.
