whats considered very high knock count with a race header??
silverspoon1996
Post by silverspoon1996 »
I am showing min 20000 at idle and over 100000 at part throttle...
The knock count should be zero when you start the car and fairly low (under 10) after driving. Can you post a short datalog of the knock count increasing?
silverspoon1996
heres my datalog... I dataloged at 6 am when it was 60 degrees out, and had zero knock count.. I will also post those. There is a difference of 30 degrees IAT.
I am getting an error message trying to upload the File... can someone help me out.
Upload Error: Could not upload Attachment to ./files/knock_count_381.fpdl.
the file is only 3.75mb.
Last edited by silverspoon1996 on Fri Jul 24, 2009 3:55 am, edited 1 time in total.
silverspoon1996
NO POST MODE SPECIFIED???? Thats the other message I get while trying to post a .fpdl
Email it to support@hondata.com, or try zipping it.
silverspoon1996
I dont know what happened.... but the knock went away... I didnt adjust anything or reload a calibration, I did absolultely nothing.
COMplex
Post by COMplex »
I'm showing quite a bit as well... 10000 to 150000. Not sure about idle and after starting, but it's a bit odd that the numbers are so high. I assume this is false knock due to s/c and race header?
Car runs well (as far as I can tell)
I would think there would be less/no knock with e85... but if it's false then I won't worry.
[COMplex] »»» civic.plex.nu
» Comptech Supercharged 2006 Honda Civic Si
» Information | Teaser Video
Have you re-uploaded your calibration with the lastest version?
Hulk69
Post by Hulk69 »
When people have a really high knock count, like in the thousands, the folks on 8th Civic figured out that it's some type of update/install glitch. If you'll uninstall and then install the latest FlashProManager, then reflash your car using the newest version, the really high knock counts stopped happening.
2009 Civic SI CBP FG2: K&N Typhoon V2 SRI | P2R TBS w/Gaskets | Strup Race Header (cat delete) | Apexi Noir Catback | Hondata FlashPro
