FP calibrations with messy ignition
vtecz
Post by vtecz »
Can anybody explain to me why the ignition maps in nearly all the calibrations are so messed up?
For instance:
"Completely stock tuned" (AFM): Ignition high-40 degrees in 8th column at 5000 rpm-33.00 at 5500-34.50 at 7000-31.5 and at 8000-33.8! Don't tell me that's tuned! Some other columns are even worse and in 2-D some are overlaying each other! I wonder if that could be why many people have some knock retard.
vtecz
Post by vtecz »
Can someone just confirm that the map I edited below would be better and safer. I'll try bunch of other stuff on the dyno of course, I just want to prepare everything so I don't have to spend days on the dyno.
The ignition tables are fine - it is normal to see a variation which results in crossed lines. There is much less ignition around the idle area so that th engine will not surge at idle.
I would not use the 'smoothed' tables - the low and high cam tables have been duplicated across all cam angle values, and in some places there is much more ignition advance that what we tuned.
vtecz
Post by vtecz »
I see, another question, seems my car runs leaner up to 4760rpm when the throttle is under 80%. Does the map reads correct? Can I add fuel by WOT lambda adj. just like on the pic below?
Thanks Hondata
