VSS (speedo) sensors
Stuart
Post by Stuart »
Running a different box to the std Honda one, without a VSS sender.
now, I have made up a sender to run on the output shaft, and this works OK< but I could do with knowing the number of pulses per turn on the std Honda setup (from an EP3 gearbox).
Would also be really useful to be able to calibrate for this in Kmanager (to cope with different tyre sizes etc).
I see there is an option for 2005 RSX with a correction, is there any way I can use this?
Stuart.
You cannot calibrate this in KManager. The stock vss signal is 4 pulses per wheel revolution.
Stuart
Post by Stuart »
Spunkster wrote:You cannot calibrate this in KManager. The stock vss signal is 4 pulses per wheel revolution.
Thanks....
any chance of this being added in future releases?
