main relay buzzing with s300
holset b18c1
Post by holset b18c1 »
not sure whats the problem but my main relay started buzzing the same day after i tryed 2 get the car tuned?? i checked for loose gound wire found none!! thromostat valve cover tranny grounds all good!! looked in the car for loose grounds none!! tryed cranking the motor will not start any more is my s300 fired??also only with the s300 the relay buzz not with the stock ecu!! car 99 civic si with gsr turbo set up!!
Try the ECU in a known good OBD1 car. It may be your adapter harness.
holset b18c1
ok i guess i will have 2 do that but i got a next relay, just in case!! also thanks for the info
kinetics
Post by kinetics »
I had this issue when I had a bad ground.
holset b18c1
need help
Where was your bad ground wire?
Got a new jumper harness and main relay ! Still buzzing
What is the battery voltage when cranking?
kinetics
Post by kinetics »
My bad ground was actually on the neg battery cable, between the fender wall, and the block.
So, basically, it was missing the block ground. It started 1 time, and then started doing the buzzing from then out, and wouldn't start.
