ROM Editor 3.5.2 Fix Rev Limiter
Dariusz
Post by Dariusz »
In this new version, the "Fix Rev Limiter in ECU" option is disabled (grey) all the time and the check box is disabled too. Is this normal or I have problems? It use the value and don't vory about this?
Thanks in advance,
Dariusz
'94 Acura Integra GSR (P72) S-200
Dariusz
Post by Dariusz »
No one in hondata can explain me this? :cry:
lcopas
problem ???
Post by lcopas »
you are correct ... the check box is grayed out on mine too ... I had not noticed it until I read you post ...
Not sure if it is a problem though .. I have mine set to 9500 ... as I do not turn it much over 9000k very often .... maybe you could try changing it real low like 4500 ...and see if it still works ....
Fixed Rev Limiter
With V3 ROMs the 'Fix rev limit in ECU' box is always greyed out as the rev limiter is always set in the ROM.
turbosi92
Re: Fixed Rev Limiter
Post by turbosi92 »
Hondata wrote:With V3 ROMs the 'Fix rev limit in ECU' box is always greyed out as the rev limiter is always set in the ROM.
THus, it can't be set in Hondalogger rev limits.
Dariusz
Post by Dariusz »
I don't understand, hondata say that the value is not possible to be changed? or say that in a romulator session it can't be changed, but in a burned rom it work?
shinociv
Post by shinociv »
Hondata is saying that the rev limit must be programmed in the rom chip or Romulator using Romeditor, it can?t be changed from Hondalogger.
