K24A4 with 05 RSX Transmission
K24Zivic
Post by K24Zivic »
Is there any way to enable the K24A4 calibation with the ability to use the VSS on a 05 RSX transmission. Currently I am just converting a RSX map to the K24A4 calibrations, however this time consuming and leaves lots of room for error.
1) 92 Civic VX: 05 K24A4 05 RSX 6 speed 06 Civic Si Shifter Electric water pump Skunk2 Stage 3 Cams OG Hasport header with 3"
2) 93 Civic K20/24 being built from tires up
3) 2017 CTR
+ Fit + Civic Hybrid + Odyssey + Grom + Ram Dually
No it cannot be enabled.
K24Zivic
Post by K24Zivic »
Is it possible to use a PRB ECU with the calibration for a K24A4 entered into a RSX-S calibration file and get a low frequency speed signal output from the high frequency 05 RSX VSS?
3) 2017 CTR
No, for an engine swap you really need to just use an 02-04 transmission, or swap your internals into a 02-04 case with a ring gear.
