Launch Control Removal
Trent009
Post by Trent009 »
Hi from Australia,
I have a Hondata s200 with the launch control option activated at 4000rpm
The problem is that I need to pass a noise test on my car. This is done by revving it to 5400 rpm in neutral. However the launch control feature limits these rpms.
How do I go about removing the launch control?
Was the s200 tuned with Romeditor 3 or 4?
wackyprelude
Post by wackyprelude »
Is it for smog (emmissions test)? Can't he just unplug it for the duration of the noise test?
Trent009
Post by Trent009 »
I'm not too sure what the tuner used, I just paid the guy, now can't get in contact with him anymore.
The test is a noise test but should it be suspect, it will go in for emissions testing.
Is there a difference between RomEditor 3 or 4?
Thanks for the replies
Yes it is different. The clutch switch is connected differently an dthere are settings in the software that are different.
Trent009
Post by Trent009 »
That's strange. I don't have a clutch switch connected to the ecu or hondata box.
I can rev to 9k in all gears except neutral.
