Low temperature thermostats
News and announcements from Hondata.
We do not recommend the use of low temperature thermostats, as this causes tuning problems since the ECU still thinks the engine is still warming up.
For those who think low temperature thermostats stop their engines over-heating - what is the difference between a 160 degree thermostat and 178 degree (stock) thermostat when the coolant is 185 degrees, and both thermostats are fully open?
2rotormotor
Post by 2rotormotor »
the 160 opens up sooner and closes later. There is a difference. thats why they have different temperature ratings. If not they would all be the same.
The point is, if your engine is overheating, a low temperature thermostat will make no difference.
