IGN on idle jumping around normal?
0piston
Post by 0piston »
Hi quick question before I add a datalog. during idle on my display I see my timing IGN jump around from 17-26 although in my "low speed ignition values all around idle are set to 20' degrees. anything i can quickly check that could be affecting this?
my "ignition compensation air temp (low load)" table under "temp compensation" are all set to 0, so I don't know why.
thanks.
Ignition timing will vary at idle, this is part of how it ocntrols the idle speed.
