o2 target voltage / AFR
ITR 1102
Post by ITR 1102 »
What is the relationship between the o2 target voltage and the closed loop AFR?
Ex: what is the desired AFR if target is set at .43 as opposed to .51?
Is this option only used to compensate for differences in the o2 sensors in order to properly reach stoich, or is this used to change the target AFR for better economy?
It can be used for either. The target is the voltage you are shooting for.
ITR 1102
Post by ITR 1102 »
is there a chart that shows the typical voltages to air to fuel ratio to use as a guide?
You will have to look at the documentation for the sensor you are using.
ITR 1102
Post by ITR 1102 »
Thank you
I will check it out :-)
