EDL Input
cukali
EDL Input
Post by cukali »
K24A1 w turbo and K-pro. 2005 EP3
I am having a problem with EDL input. I located the pin, I checked the box for using external W/B sensor, entered in V vs Lambda in the columns but I get no readings. Shoudn't the EDL in "SENSORS" reflect the voltage going to the pin? This voltage is constant at 4.7 or so even when I have the W/B hooked up or nothing hooked up. I even applied 3.0 volts to the pin and nothing. Also, it keeps changing the selections when I close the window and open it back up.
I need to know what it is I am doing wrong if you know.
thnx
No, you need to look at the AF once you have the wideband input selected.
