Water Temp Compensation - Cold Start
Quade
Post by Quade »
Which water temp compensation affects cold start? Open Loop Low, Open Loop High, Closed Loop Low, Closed Loop High? Assume closed loop enabled. Car starts fine when warm - just want to adjust the correct one.
As it is now when I give it a normal crank when cold it wont start in one. Crank again and it starts. I believe it need more fuel when starting. Yes if I hold the key long enough it would start cold the first time.
Don't change any of the compensations. Just change the cranking fuel trim plus or minus depending on what helps the car start better.
Quade
Post by Quade »
I thought about that but afterwards I was thinking that the cranking fuel trim would have an effect when it's cold as well as when it's warm and starting fine. I only want the adjustment to affect cold start. Will try it however.
Quade
Post by Quade »
Had to add as much as 20% for cranking fuel trim to get a good start when cold. Is this normal or is it because my injectors are 1000cc and lazy? Cranking when warm is still fine. Thanks.
kinetics
Post by kinetics »
Part of that is because you still have unburnt fuel in the cylinders when it's still warm.
As for cold, I had to add almost 80% for it to start on my stroked E85 B16A, and it still takes a few seconds for it to actually start, if it's a cold start.
allm0t0rGSR
COLD START
Post by allm0t0rGSR »
IS IT NORMAL TO RICH UP TO 12.6 AFR AT COLD START... BECAUSE MINE EVERYTIME I START MY CAR IN THE MORNING IT GOES TO 13.9 AFR A COUPLE SECONDS IT GOES TO 12.6 AND THE AFTER 3-4 MINS IT GOES TO 13.5 UNTIL THE CAR IS FULLY WARM? IS THIS NORMAL THAT RICH IN COLD START IN THE MORNING
This is normal
allm0t0rGSR
thanks alot
