Graph Display for MAP skewed...
peasly23
Post by peasly23 »
So I'm looking over my datalogs and am looking at my Manifold Pressure (MAP) which are in "/psi. Under my "Sensors > MAP" I have the display min and max set to "0" and "20" respectively.
However, when looking at my graph, although the left side of the graph shows 0 - 20 along the y axis, when my MAP gets up to 20 PSI the line is only like 20% up the y axis instead of all the way up.
Any ideas?
Change it to 0 and 1
inches and psi are 2 different units so it does not behave like other graph templates.
peasly23
Post by peasly23 »
I had to change it to 0 and 3 because it was still going off the chart. Now I see all vacuum and 20psi filling the whole graph correctly.
note: I hope this doesn't change my display settings in the "display" area with the guages.
