3bar or 5bar option with Hondata 4bar map sensor?
uncledan
Post by uncledan »
What option in Kmanager should I use for a Hondata 4bar map sensor for the tables? Options are 3bar map tables or 5bar map tables. I will be making around 11 psi with a JRSC.
uncledan
3 bar tables will be fine for that boost level
uncledan
Post by uncledan »
Thank you.
atomic civic
Post by atomic civic »
I have a omni power 2.5 Should I use this setting also? Thanks
yes it will be fine
