Max speed Group N
insomnia
Max speed Group N
Post by insomnia »
Is there a speed limit in the calibration of the group N?
I test with my car... below 210 kph??? :shock:
I have datalogging of this test...
Are you experiencing a speed limit?
insomnia
Post by insomnia »
Yes with default Group N calibration
I attach datalogging...
check in -> 6'
we'll double check this
insomnia
Post by insomnia »
I change gear form 5th to 4th and 5th again and always 210kph ;(
insomnia
Post by insomnia »
it's necessary send information from FlashProManager?
V1.1.0.8 fix this problem?
We've checked, and there is not speed limiter. On your datalog, which I can't open, do the injectors shut off?
insomnia
Post by insomnia »
I upload again, and not problem... :shock:
Viewing datalogging appear 91-92% TPedal when is 100% and speedometer (kph/mph) is not the same in log
And some question/suggestion... it's possible when cruise control is ON VTEC start always in upper Window rpm? (not at lower) :?:
rikitaun
Post by rikitaun »
desde 6500 rpm vas encharcado de gasolina 11-11.5 A/F quitale un 9% de sofa y dejalo en 12.5-12.7 a/f
insomnia
Post by insomnia »
rikitaun wrote:desde 6500 rpm vas encharcado de gasolina 11-11.5 A/F quitale un 9% de sofa y dejalo en 12.5-12.7 a/f
buenasss me suena tu nick :D de clubcivic?
Como ves que va la mezcla tan rica??
rikitaun
Post by rikitaun »
sip, y foroctr y hondaspirit jajajajaajajaj
lo tienes en el sensor de A/F que te indica la mezcla que llevas
14.7 o lambda 1 para ir en closeloop y gastar lo minimo
12.5-12.7 A/F o 0.86 lambda pie a fondo es lo mejor
insomnia
Post by insomnia »
Como no soy un guru del tema, voy recopilando toda la información en el foro por aquí :lol:
