s2000 lean protection
saltracer
Post by saltracer »
Hi, I have downloaded the K manager software and have been having a lot of fun with it. However, Why can't I get the lean protection in the Base map for a 2000-2003 s2000 to work. I have went into options-settings-and wide band input then set up a plx sensor. When I return to lean protection I am blocked from using this. Is this feature not avalable for the 2000-2003 s2000 If not what are my options? The 2006-2006 base map lets me play with the lean protection. Any input would be great I am purchasing a K pro for my race car this week and need to learn as much as I can about it. Thanks
dmramos
Post by dmramos »
Lean protection can only be used with the RSX wideband.
saltracer
Post by saltracer »
So if i still want to run the plx wideband I should be able to tune with wideband capabilities and monitor my a/f on the plx gauge? Right now it probably wont be a problem. But next year I want to run nitrous in a fuel class, then a turbo the year after . A way to monitor a/f would be nice even if I don't have lean protection.
Yes you can input a wideband signal from a wideband controller into the ELD input on the ECU.
saltracer
Post by saltracer »
The plx is just used for tuning in open loop and dataloging? Or for closed loop operations as well? :?:
Because the 00-05 S2000 K-Pro uses a PRA calibration which is narrowband you can input the wideband signal to the ELD and the narrowband to the OEM primary O2 input and run closed loop from the PLX.
saltracer
Post by saltracer »
Thanks for the fast response I can't wait to install my Kpro when it gets here.
Garrett_si
Post by Garrett_si »
Spunkster wrote:Because the 00-05 S2000 K-Pro uses a PRA calibration which is narrowband you can input the wideband signal to the ELD and the narrowband to the OEM primary O2 input and run closed loop from the PLX.
an Lean protection will work?
No you cannot use lean protection.
