Ep3 cluster going crazy
jdm97r
Post by jdm97r »
Hi to all,
A friend of mine has a Euro spec Civic type R EP3 2002 model and a problem occured in the electrical system of the cluster.
The lights on the cluster goes on for example you switch the lights on and the wipers work and on the cluster shows that the bootlid is open at the same time.Also with the ignition on the wiper work by them selves even without fuses in fuse box
It used to blow the ecu fuse but not all the time.
Can somebody help us please?
We tried already different ecu battery and a new fuse box (under dash ).
We checked all harness comming from the engine to the ecu as the engine is turbo'd.Added earth system also.
We are confused now
Take it to a Honda dealership.
