Secondary O2 sensor - Delete
gtracer
Post by gtracer »
Hi everyone.
I desperately need your help. I can't find the window in the FlashProManager to disable the Secondary Oxygen Sensor.
I've search on 8thcivic.com, searched on this forum, search in the FAQ of the Flashpro and look at every single table in the manager.
Could anyone tell me how to get to this point in the FlashProManager please!
I have a picture just to make things clear.
Thank you so much and I appologize in advance if I'm completely blind and didn't see it. I've been looking for an hour.
Nick
soxfan143
Post by soxfan143 »
Open the calibration tab then click on closed loop and then uncheck "secondary O2 sensor enabled"
gtracer
Post by gtracer »
soxfan143 wrote:Open the calibration tab then click on closed loop and then uncheck "secondary O2 sensor enabled"
Really?
I must be missing something. My Flashpro manager is up to date also...
Check this out. This is what I see.
then I open that.
and then i get this.
Am I missing something?
Thanks for your help.
You are looking at an AFM based calibration. THis feature is only available in a MAP based calibration.
gtracer
Post by gtracer »
Spunkster wrote:You are looking at an AFM based calibration. THis feature is only available in a MAP based calibration.
Ah ok!
Can I run the FG2/FA5, MAP based, CAI, Skunk2 header & catback with the stock MAP. I only have to make sure that the Stock 1.7 BAR Map is selected?
Thanks again.
ps. My mods are: AEM CAI, Skunk2 Header, Skunk2 70mm
As long as you have a stock map sensor then yes you leave it selected as a stock map sensor.
BV1
Post by BV1 »
I just read this as I was having the same issue. So running an AFM calibration, one has to tolerate a CEL, no access to the Throttle Tables and no larger injector support?
This is why we offer the Map based calibrations. They are much easier to tune and have more features.
