race header & rdx injectors
white05types
Post by white05types »
I know this race header thread for the 05-06 Type s has been Covered already. I knoW aboUt the lean situation but do you think that rdx injectors might help that situation. I know kpro is the way to go but right now a reflash is most feasible. My mods are injen cai, dcrh, rbcmanifold, hondata img, stock exhaust
Stock injectors are 310cc. RDX injectors are 410cc. You cannot use them without reflashing the ECU.
white05types
Thanks for the reply. I do intend to do a reflash but given the fact that with the reflash i'll run lean since i have an 05 rsx with a race header and rbc im, i was wondering if a set of rdx injectors along with the reflash will help that situation.
You cannot use a reflash and larger injectors. To run larger injectors you will have to get the K-Pro to be able to properly tune it.
