Download Error
FreshDA9
Download Error
Post by FreshDA9 »
used my ecu on my buddy's integra checking a problem i uploaded a basemap to the ecu, we had turned the car off and closed smanager properly by disconnecting before we turned the car off. i pulled the ecu then put the ecu back to check another idea. I downloaded the map from the ecu and got a error that multiplied many times across the screen. I have also had this error once before looking at a friends tune and messed the tune up as soon as i downloaded it. would like to resolve this so i have no other issues pluging into others ecu's.
More than likely you were datalogging when you tried to download from the ECU.
FreshDA9
Post by FreshDA9 »
hmm i dont remember if i was or not i might have been. ill try this later. thank you.
nscirocco
Post by nscirocco »
i tried last night and had the same problem .. access violation windows just keep poping up over and over when you try to download the map from ecu (after the dialog box that says you should double check the map)
on windows 7 64bit and version 1.4.2
The only way I'm able to reproduce this is if I am datalogging when I try to download the calibration. The solution is to make sure you are not datalogging when you download from the ecu.
