bought used kpro, can't load it???
shortstop
Post by shortstop »
not sure on serial number but i have the following info
1.3.7.0.
2004 civic si
PRB kpro
i/rh/e
Can't load kpro
I downloaded the latest kmanager after buying my used kpro. I did it with the ecu not hooked up, then i checked the lights (green steady,red flashing) so that checked out alright, plugged it into the laptop, turn the key to the on position and the bottom left corner still says ignition off. I think that is why i can't get into the options menu and erase/upload .cal's
Anybody know whats going on here? I am only running 1 version of kmanager as well, just can't figure it out from the help menu.
shortstop
Post by shortstop »
im thinking this could be my problem.
http://www.hondata.com/immobilizer.html
I drive with my ecu to the Acura dealership, they take my vin and enter it in the ecu, i load up kmanager and have the kpro then hooked up while they are doing this. Or do i go to honda?
What is the K-Pro serial number?
shortstop
Post by shortstop »
Spunkster wrote:What is the K-Pro serial number?
under the bar code on the inside it says 05001456
shortstop
Post by shortstop »
im assuming they are using the last 4 numbers? So i need the $250 upgrade?
http://www.hondata.com/kprodatalogging.html
Have you relocated the ground per the instructions?
http://www.hondata.com/techk20ground.html
shortstop
Post by shortstop »
Spunkster wrote:Have you relocated the ground per the instructions?
No. I have the stock a3 and hks circle earth ground kit. You don't think i need that update on the kpro? I am double checking the grounds in a minute. Just curious if i have to spend the cash on the update, i hope not.
shortstop
Post by shortstop »
ttt
have you relocated the ground as the instructions say?
shortstop
Post by shortstop »
Spunkster wrote:have you relocated the ground as the instructions say?
yes and still nothing. Im tryin a new wire/computer to see if that helps. I'll let you know.
shortstop
Post by shortstop »
no dice, im gonna recheck the wiring from the actual harness and see if the hks grounding kit is just weak. :(
