Civic Type R 2007-2011
Civic Type R
2007-2011
Europe
RSP-E010 to RSP-E110
International Civic Type R
2007-2011
South Africa
RSP-N010 to RSP-N030
2007-2010
Asia
RRC-J010 to RRC-J040
Features (Euro)
General
Forced induction support
Expanded tables
Live tuning
Active fuel tuning
Wideband lambda input
Boost control output
Ethanol content input
Traction control input
Fuel
AFM, MAP or hybrid AFM/MAP tuning
Injector size & fuel pressure parameters
Injector voltage compensation
MAP fuel tables
AFM fuel tables
Full load compensation tables
Overall fuel trim
Cranking fuel trim
Cranking fuel table
Cylinder fuel trim
Air temperature fuel trim
Coolant temperature fuel trim
Ignition
Ignition tables
Tip in retard compensation
Gear ignition compensation
Cylinder ignition trim
Air temperature ignition trim
Coolant temperature ignition trim
VTEC/VTC
VTEC rpm window
VTEC pressure window
VTEC conditions
VTEC oil pressure input enable/disable
Cam angle tables
VTC PID parameters
Closed loop
Short, medium and long term trim limits
Full load determination tables (MAP / TPS)
Wideband current to lambda conversion table
Target lambda
Knock
Knock ignition limit
Knock sensitivity table
Knock retard table
Rev limits
Overall rev limiter
Launch rev limiter
Speed limiter
Boost cut
Full throttle shift
Anti-lag
Sensors
AFM calibration
MAP sensor selection
Speed adjustment (ECU)
Speed adjustment (dash)
Idle
Idle speed tables
After start idle speed table
Throttle
Target throttle plate table
Overrun throttle closure (rev hang)
Tip in fuel
Misc
Various sensor enable/disable
Various DTC enable/disable
Cooling fan temperature
Features (Asia)
General
Live tuning
Fuel
MAP based tuning
MAP fuel tables
Cranking fuel table
Cylinder fuel trim
Ignition
Ignition tables
VTEC/VTC
VTEC rpm window
Cam angle tables
Closed loop
Short term trim limits
Target lambda
Knock
Knock retard table
Rev limits
Overall rev limiter
Launch rev limiter
Speed limiter
Boost cut
Full throttle shift
Anti-lag
Sensors
Idle
Idle speed tables
Throttle
Tip in fuel
Misc
1. Engine oil life not functional with the race calibration.
2. Trip meter not functional with the race calibration.
