Civic Type R
2023
US
66V-A030
CTR
2023
Japan
66V-J030
CTR
• | Turbocharger limit tables |
• | Anti lag (launch and rolling) |
Datalogging
• | Engine sensors (rpm, AFM, IAT, ECT, MAP, BP, throttle pedal and plate, knock level, knock retard) |
• | Engine outputs (ignition, injector, duty cycle, fuel pump command and pressure, VTEC) |
• | Engine special (cat temp, oil pressure) |
• | Turbocharger (wastegate command and position) |
• | Vehicle (speed, gear, battery) |
Note that datalogging an ECU that has not been reflashed will not datalog all sensors correctly.
