Civic Type R
2017+
US/Canada
5BF-A03 to 5BF-A05
5BF-A22, 5BF-A23
5BF-A34
FP-FK8-US
Americas
5BF-M03
FP-FK8-US
Americas
5BF-X03
FP-FK8-US
Euro
5BF-E03 5BF-E13 5BF-E23 5BF-E34
FP-FK8-INT
UK
5BF-G03 5BF-G12 5BF-G34
FP-FK8-INT
Australia
5BF-Q13
FP-FK8-INT
Asia
5BF-J03 5BF-J13 5BF-U12 5BF-U23
FP-FK8-INT
S Africa
5BF-N02
FP-FK8-INT
• | Turbocharger limit tables |
• | Anti lag (launch and rolling) |
Datalogging
• | Engine sensors (rpm, AFM, IAT, ECT, MAP, BP, throttle pedal and plate, knock level, knock retard) |
• | Engine outputs (ignition, injector, duty cycle, fuel pump command and pressure, VTEC) |
• | Engine special (cat temp, oil pressure) |
• | Turbocharger (wastegate command and position) |
• | Vehicle (speed, gear, battery) |
• | VSA (ABS wheel speeds, steering angle and torque, Yaw sensor, G sensor, clutch position, brake pressure) (except for vehicles with 'Honda Sensing') |
Note that datalogging an ECU that has not been reflashed will not datalog all sensors correctly.
