Instant Live Tuning is like Live Tuning but the calibration does not need to be uploaded for live tuning to function.
Like regular live tuning, instant live tuning allows for the real-time update of tables and parameters in the ECU. Some of the same limitations apply to Instant Live Tuning:
• | The FlashPro and laptop must be connected to the vehicle for changes to occur in realtime. |
• | Not all calibration tables can be live tuned. |
• | Only some of the calibration tables can be live tuned at the same time. This is because there is much more flash memory in the ECU than RAM. |
• | If the ignition is switched off and then on, the live tuning tables will reset to default values. This does not mean the tables are reset to stock values; they are reset to the values from the last calibration upload. eg if an ignition table value is 20° when the calibration is uploaded, and via live tuning you edit the calibration to 24°, then the ECU will reset the ignition to 20° if the vehicle ignition is cycled. However, if you have the FlashPro connected to the vehicle, then FlashProManager will recognize a 'key-off key-on' event, and will upload all the changes to RAM. There also is a menu command to force the update of the ECU RAM. |
Using instant live tuning
1. | Either click on the live tuning table for the parameter/table you wish to live tune, or |
2. | Use the Select Live Tuning Tables window to select multiple tables at once |
3. | Edit / tune the parameters/tables. You do not need to upload to the ECU. |
4. | When finished editing, de-select live tuning tables and upload the calibration to the ECU again. |
