Knock control parameters |
Knock sensor The knock sensor may be disabled if not present.
Note that the knock sensor normally does not need to be disabled while tuning. If the knock sensor is disabled, the ECU will use default advance tables resulting in considerable ignition retard.
Light control When enabled, this parameter will flash the check engine light when knock occurs.
