Laptop datalogging
Datalogging
Connect the FlashPro to the vehicle diagnostic port.
Connect the laptop to the FlashPro using USB.
Switch on the ignition / start the engine.
Press F10, select 'Datalog' from the datalog menu or click on the Datalog icon:
datalog-start
When datalogging FlashProManager will display sensor values, error codes and will update table tracing if a calibration is loaded, however the sensor values are not recorded.
If you wish to save the sensor values you need to record the datalog.
Recording
Press F9, select 'Record' from the datalog menu or click on the Record icon.
A recording can be saved to disk for later analysis.
