BP |
Boost Pressure (BP) and Boost Pressure Command (BPCMD)
The BP sensor measures the air pressure inside the charge pipe, before the throttle plate. The BPCMD sensor is the amount of air pressure the ECU is commanding from the turbo charger. |
