Plugins and Scripting
Introduction
FlashPro can run scripts to change calibration values and automate functions using use the Lua language https://www.lua.org/.  Scripts are packaged in the form of a Plugins.
Plugins
Plugins can either by run from the Plugin menu or can run in response to events (like loading a datalog).  A plugin can do things like update calibration parameters/tables or analyze datalogs.
Installing a Plugin
In FlashPro open the Plugins menu
Select Manage Plugins
Click the Install button
Also see Writing a plugin
Security
Plugins can change any parameter or table in a calibration.  Only install and run plugins from trusted sources.
Plugin Graphics
Work in progress.  Unsupported.
Plugin Debugger
